such a tiny tube hole, musta run over a pin
I still need to install Saints on the Heckler... when I get back from vacation... just finished up giving the neglected Spot a light cleaning, new pads and a very long overdue brake bleed. And new tires installed.
Now the Heckler is in the stand to clean off the remains of WV that I brought home... Then start getting ready for the trip to Maryland for the MoCo Epic on Sunday and then out to Bentonville... with (fingers crossed) a day at Kanuga on the way home.
This has been hanging on my wall for over 5 years now.....after many years of use, I cracked the rear triangle....@jdog got me another, but the bike was then ~7 years old and they no longer had the right color...I mean whatever, you get what you get lol....But by this time, I had bought my bronson and forgot about this thing. For its day tho, (2013) it was a really good bike....Anyway, fast forward now nearly 6 years....After giving my 11 year old nephew my wifes old 26in hardtail this summer to tool around at our lake...hes been riding with my son and really liking it...so he asked his mom for a bike with suspension for his birthday.....My sister in law then asks me what she can buy him...I like the good brother in law that I am, send her a link to a halfway decent $9000 pivot switchblade and tell her..."you do LOVE your son don't you????" Anyway....in reality she was going to spend like $300....and im like, please no...bc not only will you buy him a piece of shit, ill be stuck fixing said piece of shit. So I remembered I had this bike on my wall still....Its not a switchblade, but I think it will be better than anything he would have gotten for $300.
Frame, fork, stem, wheels were all stuff from when I took it apart....cranks were a set that @pooriggy iggy gave me years ago...cant remember why...cassette is off my bronson, brakes are the db8s off roberts new pivot as are the shifter and derailleur, handlebar I won and Johnny Gs floduro....Need to find a short dropper post for it
Lucky kid. Carbon Lefty Super Max 140?
very cool uncle/BIL.
Maybe just scuff and rattle can the rear triangle black - then again 12 year old probably doesnt GAF.
What are the insertion limits? I have a 31.6mm Manitou 150mm dropper that may work. Is it set up for internal routing?
Put a Magic Mary on the front of the Stumpy. Took the Ultra Soft Albert from that, put it on the front of the Epic, moved the Soft Albert to the back. All done in anticipation of slipperier conditions as the seasons change.
Stumpy had a squeak in the BB area, started to pull everything and noticed the rubber of the NDS dust seal was getting chewed up at the crank arm. Replaced and re-greased, see how it holds up. Oh, and for shits and giggles I re-greased the headset, too.
What compound are you using on the Magic Mary? And is that the new radial?
I run a soft out front but I was thinking of trying an ultra soft in the Super trail casing. I can run lower PSI in the Supertrail vs my current Superground casing.
Ultra soft, Trail casing in the new Radial, yes. The Ultra soft Albert doesn't show appreciable wear, and I've rode it in rotation since April, including a 4 day trip to Moab.
So after getting it together and letting my son take it for a spin...I realized that there is no way he would be able to ride it yet with a dropper....so this is the only way its going to work for now. But its together and working.
Project #1 for today was some McGuiver fixes. My Mezzer had bath oil getting trapped above the lock ring that holds the Damper in place. Seems to be a thing with some Mezzers.
Had to pull the lowers anyway since @Ryan.P was kind enough to use his burnishing tool on my bushings the other day. Thanks again Ryan. Anyway, some recommendations over on MTBR were to either drill out the nylon locking or expand some the slots to allow the fluid to flow back down to where it belongs. We'll see if it helps.
Part two of this project was dealing with a headset cup that has been loose since day one of owning this bike. Per Specialized the excess movement in the cup should be normal. I doubt it, but what else would you expect from a $15,000 bike?
Kane Head High headset shim? Not expecting this to do much. Even with wrapping it around 150% of the cup it is still looser that in should be. Next time around I'll use the whole 4-pack.
Glue still drying on project #2...
